PieThePlasterer
A bathroom on a job im doing has mostly small green tiles on, can you use blue grit on the tiles and dot and dab straight onto it? Cheeers.
Live a little go on do itA bathroom on a job im doing has mostly small green tiles on, can you use blue grit on the tiles and dot and dab straight onto it? Cheeers.
No dont do it it will bite you on the arseA bathroom on a job im doing has mostly small green tiles on, can you use blue grit on the tiles and dot and dab straight onto it? Cheeers.
Are they the old tiles that are cemented on? Pre grit says it can go over tiles, bond and skim.Being skimmed i wasnt sure because if you could skim into it on tiles then the dot and dab would stick aswell, some of the tiles are off so thought instead of hacking the rest of just board over the feckers
Don't get this if they are well stuck just grit em an dab done loads with no probs its designed for this shhit
Surely by the time it takes to blue grit it you could hack them off? How many tiles we talking here?A bathroom on a job im doing has mostly small green tiles on, can you use blue grit on the tiles and dot and dab straight onto it? Cheeers.
There is just something wrong with plastering over tiles don't care what people say i could just not do it ....but that's me .
I wouldn't your asking for troubleA bathroom on a job im doing has mostly small green tiles on, can you use blue grit on the tiles and dot and dab straight onto it? Cheeers.
god no ,the tiles will have to come off its as simple as thatA bathroom on a job im doing has mostly small green tiles on, can you use blue grit on the tiles and dot and dab straight onto it? Cheeers.
Don't get me wrong. I would advise against it. Not because it doesn't work but eventually the room will get smaller and smaller. I'm always for knocking back to base and starting again
Agreed. In a bathroom every mil counts
Take the tiles off .what happens if the tiles become loose from their backing .
Your boards become free floating
The easy way is never the best way
My motto is if your going to do a job do it right or not at all no offence
