It's the s*p*r*lex causing the drag marks
This might help
Ho ho ho happy xmas
I blame rising damp............Its like a pain in the back can be caused by your foot...........its about think outside the box for solutions
Funny you should say that Gibbo. Once upon a time when I was doing a flat refurb, my mate giving me a hand at the time accidentally put his foot through the kitchen ceiling! Id got someone in to do the plastering a d they'd finished and gone, so pissed off, I went to the local tool shop and bought a little tyzack trowel so I could get it sorted pronto. Came out ok and got away with it. Anyway, started to do a bit more skimming and it always seemed to come out ok. Anyway, bought a s*p*r*lex to get an even better finishbut I think that's when The problems started. I'm not blaming the s*p*r*lex, but I soon realised that I was using it at the wrong time being a novice. Now I'm a bit more clued up, and trying to stay off it till the right moment, I still think that I'm not always getting the finish I think I should be getting...it's still good, but now realising the limitations of being predominately self taught. You know. What I mean...I'm confusing myself now!
Stick to using normal trowels until your good enough to understand when to use it. I love my nela flex 2 but literally only final polish
Might be your bucketI'd love to say dodgy bag of finish, but prob trowel pressure Clutch. Btw, regarding the multi, I often find bits in it, almost like little black metallic flecks...any idea? Cheers mate.
Also dirty trowels I think are an issuesTBH mate I have never noticed that, but I will look out for that. In my experience ripples and bumps generally come from the finish being to thick or not leaving the previous background to dry enough, so pure weight pulls it and it becomes a f**k*r to trowel up.
Generally you will know if you got a dodgy bag of gear, it will set like f**k. 'Wickes' in my experience is the worst culprit for this, my local branch sells way out of date finish at times, got to watch them.
Magnet for finish... sounds attractive... what's the priced?Usually buy multi from Magnet Clutch. Seems like there's a fast turnaround as I grabbed a few bags yesterday from the top of a new pallet and when I popped in this morn for some cls, noticed it was nearly all gone. Cheers mate
Master the basics before you can cut corners ;-)Stick to using normal trowels until your good enough to understand when to use it. I love my nela flex 2 but literally only final polish
So important he said it 3 times....speedskim helps to get it flat but also being new I stick just to marshalltown for finishing and after a bit of trial and error now have my timings nailed
s**t WiFi hereSo important he said it 3 times....speedskim helps to get it flat but also being new I stick just to marshalltown for finishing and after a bit of trial and error now have my timings nailed
