drylining ceiling
Staff online
luke105
Hello all.
If I board the ceiling...tape the joints which I'm fine with...I just need to know about the ceiling edge?
Do I tape the internal corner then cut the excess tape on the wall once its set?
Or do I use no tape and just fill the gap around the ceiling edge then sand down?
Would love just some straight answers.
Thanks in advance!
drylining ceiling
I'll give you a straight answer, but you first.
Have you ever worn something similar to this?
Depends how good a job you want to do. Ideally to stop the ceiling edge cracking, you could tape the corner and fill down the walls 6 inches and sand.
Or you could tape up to the wall, fill and sand.
Or you could take time and cut your boards nice and tight, then caulk the corner.
The choices are endless.
Regarding the blouse....you're missing out big time. Set yourself free!
