carlos
Five less now, are there hairs standing on the back of the neck
Getting closer.
Sixty something, can't give exact figures.Getting closer.
A mug will appear with your name on it , you will feel very special as the old uncle used to sayHow will I know why I get there???
Will the laptop start flashing or something???
I thought it was meant to be a secret
Hi guys !!
i do a lot of damp course work,injecting dry zone and
hacking off on the inside, it's getting harder to get a decent price as my competition have dropped ther prices, now I'm told thay are not using sand and cement on the inside anymore thay are plaster boarding onto the brick with drywall adhesive, the guy I no who works for them says thay are using a water proof sealer on the bear brick first then dot an dabbing, will this work ? It would reduce the cost a lot but I don't want to try it without good advice..
thank you
i,ve used dry lining method,after applying a scratch coat of sand/cement at 3-1 with added integral waterproofer from screwfix,
couple of days to dry up,fix boards with drywall,couple of days after you can fix skirting with no-nails,did a couple of jobs 2 years ago without problem,i think it says on drywall bag that it is moisture resistent
these are the plums i see at the builders merchant. fek me
The damp that is in the wall still has to come out which is why you should use a vapour permiable waterproof additive. dabbing boards on to the render will just bring that moisture through the dabs
Not with my trick marra...................
:RpS_laugh:.............you little tease carlos............. av telt ya already. pm me the secret ..:RpS_wink:
I know the same trick Carlos:RpS_wink:
he pisses in the dab! ohhh! secret out
It is is still a secret/ trick, not everyone knows? Even those in the private members:-0 only the pre selected in the premium forum member lounge get this kind of info:RpS_wink:3500 posts, I believe:RpS_sneaky:
Piss contains salt, adding this to board adhesive will make the problem worse.
