Bodgett & Leggett
Hi
I'm doing a new post as this one isn't open for further replies - https://www.plasterersforum.com/threads/riblath-galv-or-stainless.47004/
Its this usual debate about galv vs SS EML. In this case, dormer cheeks (6x) on a self build chalet bungalow. I've more or less already decided on galv because of the massive price difference and i'm stretched on budget. Seen pricing for 8x2' sheet at £5 for galv and £25 for SS, £20/sheet x say 20 sheets is £400 extra!
Also I've read a lot of stuff on forums. While there's masses of arguments for and against, on balance it seems like SS is basically an insurance policy. Whereas in normal circs (I'm in Hertfordshire so not on the coast... house is averagely exposed) galv should be fine for 10/20 plus years, assuming quality workmanship (i have an excellent renderer) and also it will have Dulux exterior paint.
I'm more looking for confirmation on method - dormers already built, as timber stud cheeks with 18mm sheathing ply over (so too late for cement board) then quality breathable roofing membrane over that. I see comments about putting 25mm battens under EML to stop thermal bridging / create a vent gap. I could do this but suspect possibly an overkill, so am tempted to make do with using say 5 or 10mm nylon? spacers behind the EML that I'll screw through. Using SS screws at regular 6 inch intervals with prob a small SS washer to grab the mesh... not too big or may stop render adhering.
Also a 25mm void would surely require another solid ply/similar board to render against... not going to fill a 25mm gap with render scratch coat before it even reaches the EML.
I guess the beads will be SS anyway as exposed.
Any pragmatic comments welcome please!
Cheers
Cheers
