Eml on cement board
burty
Hi all, could do with a bit of advice, ive got a dormer to render which has been covered with a smooth faced cement board then rib lath. what process would you advise? Not sure if anything is needed to control the suction of the cement board?? 3:1 then 4:1?? Apologies for all the questions, I don't do much rendering, normally kept on the insides!
Thanks guys, trouble is the boss has already done it ready and they want sand and cement to match the house ! Last time I went over cement board I was told to mesh, SBR slurry then two coat s&c as the mesh is already any way around it?
