eml on kingspan k5
twosat
A bit of advice please.
I plan to use K5 boards secured with polyprop 90mm hammer clips. what is a good way to secure the eml before the weber coat goes on?
you buy render grade K5 boards, the membrane on these receives the weber LAC hi polymer adhesive base directly - no EML needed. you want to use a proper mushroom head hammer fixing.
is weber-lac better than weber-pral m or weber-therm?
Lac is the base for insulation board. Pral m wont stick to insulation. Weber therm is a general system mame not an indivifual product.
Sounds like your a bit confused but in order to render onto insulation you need the correct products. Very hi in polymer content and more like adhesive coats in a layered up system of coatings. Lac is webers hi poly adhesive and is part of the weber therm system anf other systems see
