marcosalcito
Hello, an old goat here, came off sites years ago and been on residential work since so i'm out of the loop when it comes to modern renders apart from some K rend and Pro rend i done years ago, hence i normally turn them down, but i've started this one , going over painted smooth old render.
I've prepped and sealed, so it has little suction and it;s solid but i'm a little confused about application times between coats and primers , so i want to primer the substrate then basecoat ewi225 , can i do same day. Then how long do i wait before applying top coat primer(coloured) and then the final topcoat(grey) .
I am doing small sections , biggest approx 8m square, i can sand cement render pretty quick , can i handle this alone in the present weather( mild 17C) probably have a labourer for the 8m?
I've spoke to ewi several times only to get different advice and conflicting instructions every time! so i would appreciate advice from the hands on side of things
