D
Deleted member 23452
Guest
Sometimes they aren't up to the job.
Hope no one was under that!
Bloody hell like a sheet in the wind
Scary how easy it came off. What was the reason for it thou?
I think as said above its base oat mesh and TC, it's failed because of bad key just like any render would. I would of used Parex micro or Jub vezercryl first and more pins in the base coatScary how easy it came off. What was the reason for it thou?
Ewi is big on the continent for decades, not as many grants as here in the UK, people still doing it cos it's worth it. 90% of new builds have it.Anyone been to Poland? EWI everywhere.
Is the vezercryl any good mate?I think as said above its base oat mesh and TC, it's failed because of bad key just like any render would. I would of used Parex micro or Jub vezercryl first and more pins in the base coat
Vezercryl is very good mate, there only small tubs though, but can water down about 30 percent . Cheaper to use micro. But if I'm using Jub I stick to there products for guarantee mateIs the vezercryl any good mate?
Is it like microgobetis?
I will need some for a jub render only system over concrete
CheersVezercryl is very good mate, there only small tubs though, but can water down about 30 percent . Cheaper to use micro. But if I'm using Jub I stick to there products for guarantee mate
Would you pin also ?Cheers
It's 14 flats on a timber frame although the ground level in a concrete base
Gary pearcey is sorting out the spec so I'm sure he'll sort me out!!
14 flats good m2, there mate. Love the Jub hope it goes well for you mateCheers
i don't think you will need to mate as the vezercryl sticks like to a blanket and there base coat does tooWould you pin also ?
I thought you had only been in the game 5/6 years mate?20 yrs ago the permarock system was rockwool which was bedded on with adhesive then scrimmed then pinned, pins were then spotted with bedding mortar followed with pebble dash. It makes more sense to me for the pins to go after mesh, it wasn't until the texture coats came about that this changed.
Over 20 yrs I'm sad to say. Brought up on ewi from school mate had a long spell away from it to learn the internal shite.I thought you had only been in the game 5/6 years mate?
Yes probably more like 30 yrs.Has it been getting used that long cross the big pond. I thought it was just a new thing that hit the market in the last 7 years. I'd never seen it once untill the recession hit.
Yes true, do you think it's a better way of fixing? Done any permarock lately?with the permaroc system you do the same prep for stone dash as you do for bucket coat. pins through the mesh every 500mm apart.
Never liked jugging cos it was too messy and like you say it wouldn't bond well enough.we always have a pull test permaroc is a good system.
we have had the boards ripped off by wind before it has been scrimmed on tower blocks.
you do have to make sure the boarders are using dabs and not mixing the base coat coat wet and just pouring it onto the board, this is called jugging, and it is a lot faster, and can fail.
Ginger bloke used to come out and do the pull tests and Oliff brothers were supervisors, do you know if they are still about?
Back when I started there was only a handful of firms did it and pretty much got to chose the work now every mug is at it.
Earnt better money out of it when I was 21 than I do now I'm 37.
30yrs!! I'm sure its only took off in the last 10 thou. I used to get builders mags/ home building mags from the UK for years and never seen it in them so it mustin be that popular!
You ever worked for ECL malc under Tony Bushby?we have also been fitting ewi for 30 years. in the uk and the netherlands.
Do you have a number for him you could pm me please.yes i know tony, he must be the best known person in ewi in london. he was with tei. tellings external installations london, in those days
we caught him a year or so ago he was on his phone in b and q car park in colchester, we gave him a good blast of the hooter and shouted to him to get out of the way or we would run him over! he laughed and asked if we would do the ewi on the tower blocks at essex uni.
