MartyMcfly
alumasc
Allow me to disagree sir. Wetherby is the best by far
Well only from what I've heard they have failed on phenolic miserable y'all over the uk.Allow me to disagree sir. Wetherby is the best by far
Phonolic boards come from the same place they all buy them from the same placeWell only from what I've heard they have failed on phenolic miserable y'all over the uk.
But I could be wrong.
But I've seen it with my own eyes with specs followed by approves installers
Never had problem , easy to work, predictable, you can correct mistakes , top quality I would sayPhonolic boards come from the same place they all buy them from the same place
Weatherby is s**t compared to alumasc or MR for the older ones in the room
YeahThey failed because of labour , not product quality
What about the Hotpoint machines? whose to blame for that?
There is only one way of installing phenolic boards- dab and fix. Majority of works have been done only with fixings to cut the cost and boost the profite .Well only from what I've heard they have failed on phenolic miserable y'all over the uk.
Now, that's how uk will finally have positive results with the rising damp!What about the Hotpoint machines? whose to blame for that?
Phenolic is expensive for bgYeah
You will find British gas jobs are all f**k*d
So am confusedThere is only one way of installing phenolic boards- dab and fix. Majority of works have been done only with fixings to cut the cost and boost the profite .
So am confused
Profit before quality by official installers that know how to fit this stuff
They done a job in cornwall with it mate it was the worst i think i have ever seen.
Better than your man's pics right enough
The reps have been s**t then for allowing it happen ! Was you on probation ?
How do you post the "f**k off " avatar ?The reps have been s**t then for allowing it happen ! Was you on probation ?
I've never used the gear mateThe reps have been s**t then for allowing it happen ! Was you on probation ?
Press quoteHow do you post the "f**k off " avatar ?
But have heard a few story's and there was 500 m2 failed here a couple of years ago because they were fitted and got wet over time then after everyone moved in and banged the heating on they shrunk and didn't look pretty so they had to be over coated.
Am sure if done properly it's fine
sound job take no notice of him mate,it looks neat and tidy compared to some of the s**t ive had to go overCheap? It was free dickhead!
Why aren't you telling me how you learnt?
Here's your pictures pick fault puss puss.
This enough?
When you gonna man up?
Sound job rips under 300mm and no dog legs in at the Windows or 300 centres at the cornerssound job take no notice of him mate,it looks neat and tidy compared to some of the s**t ive had to go over
Yeah looks legit
Hi all
Starting our first EWI job tomorrow, Just wondering what people's advice is on fixing and cutting EPS boards?
Do you prefer the dab or full notched bed and what trowels do people use? Just a tile trowel?
Have some flat areas and some stone work to go over.
Cheers
Phenolic will be prone to curling regardless of stick and pin or dry fix or whatever background.
Kinhspans bighest sectret. Phenolic is an unstable material and in some cases will curl up to 12 months after fitting.
Ive inspected loads of failed phenol sysyems. The very reason why sto and many others have removed it from there spec list unless deemed necessary. It was a break into rwi when eps was the original insulant along with wool. Eps will not be beaten for useability
Why phenolic will curl after installation regardless the background ?
And why do you think eps is best and better product?
Strange that! Regarding the quality of the k5 I will say xactly the opposite to your statement. Jobs with phenolic on for years is still ok and tbh never had problem or call back for cracks or something else.It curls because its still active. That is the reason its unsuitable for ewi. When u need a flat and plumb job u need a stable board. Eps is stable after production
Gases constantly escape phenolic. The u-value actually gets gets worse over time due to this also. It is just fractionally but still.
U can rasp eps too. Makes a sweet surface for coating. Most phenolic clad will struggle with the thinner base coats unless u dubb firs if boards dont sit perfectly.
Thats why wetherby use hp12 over it. I can get oit of jail 6mm or more if needed and can be flaoted or sponged etc because it was essentially designed for masonry not insulant. A true adhesive for mesh is trowel finish. That said u can get that with scrim adhesive (hp12 in amother bag) if the background is spot on.
As for the eps I can't say is better quality, but suits better the market- low cost and flexibility which will allow you to pin it to any surface and will follow the background , more or less, and will stay like this . Phenolic on the other hand is the opposite - it will brake, soon or later. And here is where the eps wins.no wonder companies are coming up with porkies to make more profit, as usual.
