Expanding foam??
Tommyd
Where gaps are big in tacking is it the done thing to use expanding foam ? Then cut back when dry?? Bonding will crack and fall out is there any other methods for large gaps in tacking ??
I mean in dodgey barns where joists are everywhere and are about as straight as a roundabout , and not a pro at scripeing so little gaps are innevitable?
if they are only small gaps, bond out scrim over them. you do need to learn how to scribe.
Are you one of the ******* Latvians I've been following? Poxy foam everywhere.
