tapit Well-Known Member Oct 27, 2019 #36 Rossi46 said: Just get the right stuff. Going to all this trouble then cutting corners is foolish. Click to expand... not if it works.
Rossi46 Private Member Oct 27, 2019 #37 tapit said: not if it works. Click to expand... That’s the point though. It might not and then have to be done again. Why take the risk?
tapit Well-Known Member Oct 27, 2019 #38 Rossi46 said: That’s the point though. It might not and then have to be done again. Why take the risk? Click to expand... because it is stronger, more water resistant and less prone to movement than wpb plywood which is used externally on loads of projects.
Rossi46 Private Member Oct 27, 2019 #39 tapit said: because it is stronger, more water resistant and less prone to movement than wpb plywood which is used externally on loads of projects. Click to expand... The state internal only for a reason. Don’t you think they’d rather sell for exterior too? Make loads more sales.
S Sicskate New Member Oct 28, 2019 #40 Just spoken to the guy doing the render, he said I could use an EPS. Is this a good solution??
