Is it the same set up for both? Or is it nearly £500 plus vat for each set up?
Cheers
And a ritmo will knock it for you
So when is the price and data released on this puppy?The M-tec M200 should be your goal ;-)
The airless and skim set up are very different mate. £460.00 + VAT each.
£460 for the m200 ?
So what exactly comes with each eze set up?
and the point in this when i think he wants it for skim lolI suppose top coat needs knocking up.... What the machine is designed for.
Oh yes, and airless.![]()
Have you tried it with your ezeI just use a hopper gun. A lot easier and less cleaning.
Can I comeGive me a call Monday and I will give you the lists mate. Off to bed now![]()
I haven't to be honest. It's the cleaning down that put me off.Have you tried it with your eze
Ill have one!That skim set up is ace for getting microgobetis on, just need a smaller than skim nozzle.
It's so accurate to spray with barely any mess.I haven't to be honest. It's the cleaning down that put me off.
I sprayef on 0 speed the other day and covered 120 m2 in an hour and half and that was with alot of stopping to drink coffee and chat.
It's also nice to be able to reach high with that lance.
Drop film the hopper and the cleaning is minimal.
On this job a roller wouldn't of touched it, it would of been a brush job for 2 men for a day easy. Glad I used the eze on my own.
I'll have to give it a go. How much is the smaller nozzle?
Hopper gun is fairly accurate but there is a bit of overspray. It's just so easy with just the compressor, air pipes and gun. Not much to lug about. Cleaning takes 2 minutes.
Why?The M-tec M200 should be your goal ;-)
Why?
Could I adapt my eze to run airless without a visit to the doctor.To be honest, writing very different was incorrect. I'm going to re-do the additional setup price if one is already purchased.
For example, the machine come with the render setup. If the skim setup is required then that's an extra £460. If you purchase that then want the airless it won't be £460.
The guns are completely different on each setup as are the hoses
We just need to send you the bits mate
