theclemo
how many bags at a time can u put in the eze ?
the same as a ritmo
Out of interest Ryan , what distance will the EZE 24 pump when applying textured top coats .Also if I don't have any power available on site what kind of generator would to power it cheers.Wow this has certainly been an interesting read. Sorry for my lack of comments on this. I have been away at the show, Price Plastering and Clemo, thanks for the tags.
Unfortunately the EZE 24 wont spray Basecoats Airless. However, it will spray Knauf airless Products.
@Vinnie, you have made comments about the EZE being Crap and pointless, you have then assumed what the mixing unit does. You have tried to compare it to a G4 also. You may well have experience with machines but you certainly have no experience or knowledge with the EZE 24 making every point you just made a load of rubbish!
The EZE 24 for your information was designed for the EWI Market. Mainly to spray Topcoats - which don't require mixing... The machine in this sector has performed amazingly where customers have even applied 500m2 of 1.5mm Silicone top Coat per day, due to the efficiency and effectiveness of the machine the top coats do no require rubbing up.
A bonus for the EZE 24 is that it will spray up-to a 4mm aggregate size, meaning you can also spray Scratch Renders, Basecoats and Pre Bagged Sand and Cement. This is ideal for smaller outfits, 1 or 2 man bands who are not looking to apply 200m2 of Scratch Render in a day. We wouldn't even recommend this machine for that amount of work! And we certainly wouldn't recommend a Ritmo or even a M100 for that size of work either. If you are day in day out looking to do this volume of work a 3 Phase machine or Diesel Machine is best suited. Be it an M330, G4 or whatever floats your boat!
The other positive on the EZE 24 is the simplicity of it. It is 'Easy' or 'EZE' to use, 1 Speed control, 1 Button to start and 1 to stop. It is also extremely quick to set up and extremely quick to clean down.
Also the manoeuvrability of the machine. It is 110v and only weighs 46kg meaning it can be moved easily by one man and can be used on any site in the UK!
We have had the machine being used on tower blocks to spray T/C and Basecoat, all the contractors arranged was for a 110v supply on each lift, the correct amount of materials and off they went.
This is only touching briefly on what the machine can do, if anyone has any questions on the machine, please do not hesitate to get in touch and we can arrange a demo for you.
Ryan
@wiganlad
Thanks for the questions, answers as follows:
Conveying distance for Texture: Up-to 32m on the standard setup using a 5KVa transformer
Generator size: 9KvA
