John j
Mono Don
Allways have some in vanJob on during the week, guy took bog roll out toilet before he went to work. I avoid customers toilets if I can.
What the actual f**kJob on during the week, guy took bog roll out toilet before he went to work. I avoid customers toilets if I can.
Those lines just 'settled down' on their own, don't try to kid us.
Looks gorgeous, how did you approach doing the ceiling with the hole?
Need a foot and stella photo now x
hair?![]()
I put some hair around it.
Meaning I turned it into a pussy thus easier to approach x
Ok ok
So the new roof joists were on the piss. Then this insulation was installed, then even worse joists put over the top. Just one of them ones.
Board ceiling n make some frame work where it meets doors to take board.. and also weight of curtain poles etc.
Prepped walls bit of bonding n pva ,scrim beads etc. then went back other day to skim it.put ceiling and all The reveals on new mix put all walls on then laid it
All down together new mix
Gear was greasy
Looks arm aching work, helps me with construction theory too x
The question everyone else will be asking - did you have a go on the trampoline?
lol didnt even notice it til you said. im all walls n ceiling when grafting . was an old lady in room on day 1 didnt notice her
U want to work on your angels,get them sharper pal looks like u tickled the ceiling line in with a brush
Catch it with a brush at right time and you can’t see any brush marks.@Ritch you really shouldn’t be using a brush pal that’s rough. You’d be lucky to be paid if left it all brushed in round here.
Angles are the first thing you see in a room. Even on them wonky old rooms you’ve got to get them sharp!
