DRplastering
anyone know the water setting for fassa ? first time using it tomorrow. spraying about 12 for a friday scrape
260 on the l 380 on the turboanyone know the water setting for fassa ? first time using it tomorrow. spraying about 12 for a friday scrape
It’s very slow setter and easy to work with.
Rigsby is right on the water setting as it looks wet and sounds different out the gun but don’t worry it builds out really well.
The only thing I found is that if you spray to stiff you get lots of bullet holes when scraping back next day, other than that it’s good stuff.
I was at 2.10 on 20m hose.anyone know the water setting for fassa ? first time using it tomorrow. spraying about 12 for a friday scrape
I did loads last year one pass no problems 15 mmIts the sort of gear you have to do two passes. Simple. Also leave it to pick up nicely, if you rule this off too soon it will sag.
Done loads of fassa this year. Nice gear, but needs a proper working with a serated edge. No one coat work.
Got about 8 pallets from a r and s using it. B42l soft.
