essexandy
The Lake Governor
You are a f**k**g loon bin my friend.It's going in my pink book , f**k what BG say
I'll put you down for first editionYou are a fkg loon bin my friend.
New edition of white book ( for plastering , dry lining and how to f**k up a sparky who won't take advise on first fix )What pink book mean
Not always practical but prefer to lay scrim on top of first coat and flatten in , think it has a stronger bond ( not 40 m ceilings lol)
What u want that book for mateNew edition of white book ( for plastering , dry lining and how to f**k up a sparky who won't take advise on first fix )
Paper tape for the joints and hessian scrim around the edge of the ceilings is what I was taught nearly thirty years ago.Then the self adhesive scrim took over but I still reckon the paper tape is the best job.plasterers that don't even know what bandage scrim is /think im on the wrong place here
I'm videoing it , just for easy digestion and less misinterpretationWhat u want that book for mate
Now that is a proper old school ceiling scaffold. Respect.Paper tape for the joints and hessian scrim around the edge of the ceilings is what I was taught nearly thirty years ago.Then the self adhesive scrim took over but I still reckon the paper tape is the best job.View attachment 32920
I wish they were all too high for stilts Andy!.The builder had that up when we got there.Now that is a proper old school ceiling scaffold. Respect.
to safe for me not used to such luxurysNow that is a proper old school ceiling scaffold. Respect.
I've not worked on a full scaffold since I was with the old man.to safe for me not used to such luxurys
one of my last onesI've not worked on a full scaffold since I was with the old man.
That's a belting bit of skimming Norman, was it over Artex?one of my last ones
that's as near to god as I ever will beThat's a belting bit of skimming Norman, was it over Artex?
Not according to BG Danny. Apparently the BG blue scrim is 30% stronger than paper.Paper tape is stronger if applied correctly
But is it even stronger still if not stuck under skim but trowelled onto first coat , ( according to the pink book )Not according to BG Danny. Apparently the BG blue scrim is 30% stronger than paper.
How things change.
He couldn't afford itGo get some therapy, @Danny will pick up the tab.
He can afford anything.He couldn't afford it
I am going to get some and show you something that blew my mind when I saw itNot according to BG Danny. Apparently the BG blue scrim is 30% stronger than paper.
How things change.
The tape needs to have gear behind it and on top of it to be effective... when tape has failed in ceilings in the past it is because it had been applied on the boards without any gear behind it.But is it even stronger still if not stuck under skim but trowelled onto first coat , ( according to the pink book )
Also with tapered boards put skrim in first fill and in first coat , tapered boards on a ceiling is a no no ( flex requirement )The tape needs to have gear behind it and on top of it to be effective... when tape has failed in ceilings in the past it is because it had been applied on the boards without any gear behind it.
Just doesn't make sense not to ( apart from effort ) , ceiling joints flex both up and down in relation to the next joist and so tape only to one side of the cross section has less effect to prevent the plaster from cracking , Ott I know as its only 3-5 mm , but another contributing factor is that the plaster is bonded to the board less and relying to some extent on the glueeven on square edge boards I tend to fill out my joints first...
any one having trouble with novipro tape its doing my head in outside edge sticking to roll when pulling off thru 2 out today fcking shite
What's 3-5mm? Skim is supposed to be 2mm.Just doesn't make sense not to ( apart from effort ) , ceiling joints flex both up and down in relation to the next joist and so tape only to one side of the cross section has less effect to prevent the plaster from cracking , Ott I know as its only 3-5 mm , but another contributing factor is that the plaster is bonded to the board less and relying to some extent on the glue
Do you think in reality its 2 mm where the tape isWhat's 3-5mm? Skim is supposed to be 2mm.
sooner buy the right for job customer paying any wayYou can fix this by making a cut on the edge of the tape on both sides. I cut my rolls or mesh tape 2x on each side. Just the outer band or 2 of the fiberglass. That way when a string starts to form is only about 6 inches long at any one point. Doesn't compromise the mesh and eliminates that annoying string that either builds up on the roll or pulls off from a long run of mesh.
Yes.Do you think in reality its 2 mm where the tape is
Thin as possible is best don't disagree , think that cracks on ceilings more likely the thicker it is , but apart from the inconvenience would still prefer the tape in the skim and not as a barrier to the skim , don't get me wrong I intend to hit the sites this summer and I know what method I'll choose lolYes.
