Arti
have a read....................HEAT RESISTANT MATERIALS FOR FIREPLACES & STOVES | VITCAS Refractories
Do you have to use sand and cement on the face and sides of the chimney bread when a open fire will be getting installed? say hardwall everything from brickwork then sand and cement on the inside?
never sure so i always sand and cement
I have a multi burner in my own house and did the same here as I do for customers. really clean the brickwork/block inside the fireplace if it had a lot of soot on brick/block I'd EML as well as a slurry of SBR cement and water(EML after slurry) then two coat sand cement plain float finish (the insides and back. according to the fire installer they (not me) reckon k-rend the best for heat resistance!? the opening on my fireplace isn't as much as the regs reccomend for my burner but still had no problems nor have any customers. be sure to put SBR in your mixes aswell
I reckon he's done that job now mate :rolleyes)
Just posted some questions in an old thread not realising it was in the DIY section so I'll try again here.
Is one 10cm coat of sand lime cem render with 1 coat of vitcas finishing plaster okay for opening around log burner?
Does the render have to be fully dry before vitcas applied? If so should the render be Pva'd or Blue gritted or other?
Yes you can, I spoke to vitcas about this and he gave the ok. The only down side though is you need to leave the scratch coat to cure ionger than if you were to use the vitcas mix at 25mm
If the customer is paying and knows the cost of the materials then stick with vitcas but I suspect your trying to keep down costs?
Just with normal board addy mate?
aye.................:RpS_thumbup:
you the man :RpS_cool:I do work for a local stove company. been doing their work for two years now with no call backs.
I put mesh angle beads up and bond the inside out and patchup on the outside, I then use heat resistant plaster on the inside and normal finish on the outside. can get one done in 2 1/2 hours so doing two a day isn't a problem.
I would keep that secret to yourself it's amazingI could go into details but not sure to give the secrets away???
And iv not had one call back for cracked or crazed plaster.
