obeygiant1987
Hi. I'm new to the forum and new to plastering/skimming. I likely need to deal with a few rooms but making a start on the small box room first which is a bit of a mess I feel. I've removed some lining paper that had very big bubbles under it and looked a mess. There's also a stick on strip around the room but it's difficult to remove. I've taken care of removing any loose bits that might cause an issue I feel.
The process I'm looking to follow based on my research is to use a PVA/water mix (2 coats?), a bonding coat and then multi finish. I'm looking to use a trowel to apply the plaster and a SpeedSkim to make good and level.
Seeing the pictures below to get an idea of the current state of the room would this be the best approach and is there any advice I should follow?
Tony
Tony
