Hi all,
I have had a browse through the forum already, but can't find anything concrete which seems to fit my specific situation. Apologies if I'm being particularly blind.
I am working on replastering an external wall in my victorian terrace, which is a mixture of brick and stone whose original plaster was shot. I have pulled it all off now and I am happy with the surface preparation and the basic principles of float and set ( i think these are the correct words?), having done a couple of similar walls and a ceiling previously. However, I have not encountered external corners before now, and am not sure how best to account for them.
The original window used wooden beads for the change in angle, but I can only find a reference to 90-degree corner beads, so what would be the recommended technique to form these corners?
Do I use stop beads and do one side of the corner at a time, and if so, should they be set in place before the hardwall is applied, or immediately prior to skimming?
The head of the window comprises a wooden board. with lathe and plasterwork over this - is the best approach to plasterboard this section?
thanks in advance,
J
thanks in advance,
J
