floating - ok to use soft sand instead of sharp?
ksjs
as the title says: is this ok? if you use soft what sort of problems do you get? thanks
Youre better using sharp or plastering sand only or a mix of sharp and soft (building) sand.
If you only use building sand it can sometimes be difficult to work with in the ruling off and floating stage.
