Stevieo
Royal Spin Doctor
Well you do. Stupid fingers and thumbs that end in a ball instead of a graceful tip like mine. I imagine they probably had suckers on them when you were bornYou’re just jealous of my thumbs.
Thumb envy!
Thumb envy!
He can't answear because he's not right.if he can't free rule a wall to flat and needs screeds that's chunkys problemYou didn't answer my question at all fact is if you can float you can float no matter how you look at it you are covering an area please explain what you are going to do in-between the two screeds at the end of a wall 10 meters long
Thermalites are a pain in the arsesurprised no one's mentioned
the block work you onto![]()
Yeah they suck like a prostitute on priceThermalites are a pain in the arse
Using old ways doesn't guarantee or achieve f**k all either it's down to the skill of the individual doing the job it's that simpleHe can't answear because he's not right.if he can't free rule a wall to flat and needs screeds that's chunkys problem![]()
Have you seen state of walls on old homes..feet out of square and plumb let alone inchesUsing old ways doesn't guarantee or achieve f**k all either it's down to the skill of the individual doing the job it's that simple
in a room start at left put box screeds on then fill in/ screed off put top on above the horizontal screed darby it in /rub up with wood float with nails in /cut angles out job done ready for finish coathello all
havnt been on here for a while as i have hung me tools up (some would say thank f**k), and am now teaching plastering old school styley at a college ,,,,the teacher before me had taught the kids to start floating (hardwall,, sand n cement ie) from the left hand side of the wall starting at the bottom,,,,,have i missed something here or was he a complete prick having it off,,,,surely its top right work left right handed,,or at least start at top left work right,,,,thanks for replies
straight or flat wasnt an issue then /they could do it though just look along the screeds what the cornice work is run on perfectHave you seen state of walls on old homes..feet out of square and plumb let alone inches
ouve got the cleanest hop up I’ve ever seenFloating both sides of this wall, it has a 30mm bulge one side and 30mm belly the other from one end to other. Shocking blockwork, builder said ‘bend the plaster’
Lord above, give me the strength to carry on!
View attachment 68747View attachment 68748
All depends on the person when floating really long walls I box screed all around then drop a screed in the middle to break the wall up so it’s easier to get your wall level and flat in manageable sectionsYou didn't answer my question at all fact is if you can float you can float no matter how you look at it you are covering an area please explain what you are going to do in-between the two screeds at the end of a wall 10 meters long
Some people find it harder than others it's the same with everything a lot of plastering comes down to skill and experience with confidence being a big factor tooAll depends on the person when floating really long walls I box screed all around then drop a screed in the middle to break the wall up so it’s easier to get your wall level and flat in manageable sections
Take another photo with a 1.8m spirt level, then I may be impressed.
I thought that but noticed he cleaned up drops before photoAnd why? - D'ye see how little he's dropped - respect
You put a horizontal screed at eye level ish and a screed at skirting level and rule off the two horizontalsYou didn't answer my question at all fact is if you can float you can float no matter how you look at it you are covering an area please explain what you are going to do in-between the two screeds at the end of a wall 10 meters long
Is he cracking on with your ultraflex method laying onno...
that's nonsense
why spend more time up and down on a hop up/crate
than starting at the bottom..
my apprentice spent 3 years in college poor c**t wasted his time
Yeah that's one way he didn't know though did he or you'd just float it like a pro and not mess about with screedsYou put a horizontal screed at eye level ish and a screed at skirting level and rule off the two horizontals![]()
Sack the lab if youve got to devil before finishing wall and you've forgot the eml for the wall plate.Floating both sides of this wall, it has a 30mm bulge one side and 30mm belly the other from one end to other. Shocking blockwork, builder said ‘bend the plaster’
he already has....he's just got an enormous fat handTake another photo with a 1.8m spirt level, then I may be impressed.
That looks fookin hot in Florida.
You do whatever you thinkYeah that's one way he didn't know though did he or you'd just float it like a pro and not mess about with screeds
EML there mate. Get yourself down Specsavers.Sack the lab if youve got to devil before finishing wall and you've forgot the eml for the wall plate.
head but to his ball bag then run like f**kI'll need a set of steps.
You tell him, but let me get gone first!rough as a bears arse
most domestic plasterers can't float for toffee....
Thats why they push plasterboard relentlessly...
If you cant float then you are a skimmer
what a load of s**t lolhe left ages ago mate
hes wiping arses for a living now working in care homes![]()
