Flooded Bathroom, Will Boards Be Ok.
Dopey
Attached photos of last night, this morning most water marks have disappeared.
The bath overflowed, I think most of the water was contained in the fully tiled bathroom. However this was the water marks after a hour. I’ve had the fans going all night and cut a hole to remove as much wet insulation as I can.
All walls effected are dot and dabbed on breeze block.
Do you think I’ve got away with it or should I cut it out and reboard?
  • Flooded Bathroom, Will Boards Be Ok.
Pictures through the holes
