ProofShield
We're looking for ways to increase the visibility of our insulating render product in the UK and have decided that the best way is to get it into the hands of people that will make good use of it and give us feedback for case studies in return.
ProofTherm insulating render is a lightweight, breathable render that provides both thermal and acoustic insulation. Its ideal use is in older properties that need to retain vapour permeability or where it's just not practical to go down the route of using an EPS based system.
It can be applied by hand or machine and goes on in 20mm layers. It can be built up to 10cm if required, however typically in the UK its being used at between 20mm and 60mm.
Our offer is this:
This is a good opportunity to make some real margin on a job and add an extra product to your skills and experience bank. It will help us out as well and we always look after our friends
So, do get in touch if you think you can help and have a project that will be suitable.
Call Andy on 07887-351071
ProofTherm Insulating Render
Our offer is this:
- We will supply the primer and insulating render free of charge
- Carriage from Sittingbourne in Kent will need to be paid for
- For individual projects where we can get before and after pictures and installation pictures along with a review of the installation process from you that will be used by us as a case study
- Project details/pictures to be submitted to us in advance for approval
- Whilst stocks last
