Spreadsupplier
too dear to last ill give it a shot but to expensive to last any time, does any of your hertfordshire branches stock it particularly hoddesdon
Looks like Bishops Stortford TP is your closest stockist!
Bought some today £7.49 plus vat.jamesthefirst, T.P. Stratford have now got Uni-Finish in stock
Skimming a painted ceiling Monday and artex ceiling Tuesday so will let you know.To the product that is where did you use it?
How will plaster stick to dry artex sealer will not work only works with artex as artex has some kind of adhesion in itGet yourself some Artex Sealer, use instead of PVA. One coat and you should be good to go.
Ok used this stuff on 2 ceilings and it has gone as expected. Painted ceiling 15m in a 10year old house that had cracked on all the joins.First coat pulled in as others on here had mentioned so i made sure i had mixed too much up and flattened it in with some uni straight away. This was left for a bit longer than i would on board then second coated. Went on nice and easy and trowelled up ok aswell. Reminds me of carlite finish actually although that must be ten years since i used it.
Now the artex ceiling was 19 m and i could tell this was gonna suck in fast on the first coat which it did. Again i had some extra mixed up so i flatten straight away but not with a dry trowel, in effect it gets 3 coats in total. As i put on the first 10 metres i kept expecting it to craze or crack but it just bubbled a little.
I have some more artex ceilings to skim over in this house and will experiment with coating over the uni with multi to see how that goes.
Also had some patching to run in where 3 lengths of coving been removed and this had plaster and paint to get over and went on and trowelled/blended in a treat.
Sounds like it would be a helluva lot easier to whack some pva on than to arse about with that.
Yes I think your right.
Never used the stuff mate and the moment you mentioned mixing a bit extra up (£8 a bag) i decided i never would.
I dont think that BG recommend 3 coating with it.
You would think if first coat is pulling in quick that you could lay on with same mix for second coat.
So if bondit had no grit would it still work all of them on the market all have some kind of grit or recycled plastic for plaster to grip too , artex sealer is only a suction controller ,bit like plastering dry PVa , have no problem getting hold of sealer m8 as still do lots of artexing but would still not try painting sealer on a existing artex ceiling or a painted wall then skim it ( try b&q or Dulux decorating centre they both stock sealer only in 2.5 litres now )Same as it does to bond it, wba et al.
I was told by a spread and didn't believe it myself, then was shown and it works. You don't have to try it, Ashley, but I use it a lot of the time and have, not once, been called back.
The trouble I have is getting hold of the stuff.
If you can get hold of some, paint some on an old bit of plasterboard when you do your next job as a test and if it works I want you to come back and give me a "like":RpS_thumbup:
Your right plasterboard don't have a key only the paper but then it don't need one ffsThen throw some sand in it ffs.
The Artex is the key.
Does plasterboard have a key?
Has anyone 2 coated with same mix yet?
I never second coat with the same mix and pass it as the finished job.
Thats what I did, but the artex pattern at that stage is still showing through so I let it pullin a bit longer before fresh batch and finish.
As for a painted ceiling with either hi or low suction it still gets a fresh batch mixed up as its final coat.
So when you do a small patch do you mix a fresh batch for the top coat?
These are my rules which have kept me in regular work for over 20 years.If you brush your teeth do you spend at least five seconds on each tooth? It is recommended.
I certainly hope so, they could all fall out if the rules aren't adhered to.
Id be lying if I said yes.But I still think my walls and ceilings look better with my method rather than second coating with first mix.
Fair play, whatever works for you marra, but I regularly use the same batch to second coat. I know a lot of the lads like to use a fresh batch for their second coat, but they also trowel in their first coat and wait a while whereas I just bang it on and once I've got the walls on that I want I just turn round and second-coat everything. If I've got some gear left from first-coating I ain't fkin throwing it, so it goes on the walls. Mind you - my first coat is nice and neat................I'm great I am :RpS_thumbup:
