User___removed
Just a quick question@bobby
Quick question as I saw you post on FB that you think what I'm saying is a sales pitch.... And obviously a competitor says I'm lying.
1. If the Harrington was so good, which they previously promoted, why is there a new one?
2. If 12.5KvA is all that's required, why have they brought out a 15KvA?
This isn't a dig, so I don't need to calm down etc. Just raising a valid point as you clearly don't believe what I say.
To add to this;
@UKPlasteringmachines - you mention a larger gene is overkill. This will potentially lower the lifespan of your machine.....
You can have a 500 or a 5000KvA generator, you can plug your machine into a 63Amp socket - the machine will only draw what it needs.
If your knowledge was as good as you state, then you will know that it's all down to the Hz. Too many and it can burn out your motor, too little will burn out your motor.
Therefore what actually causes damage to a machine is an under powered generator - that is a fact!
Why are you sneaking around over looking on a Facebook group that you've been kicked off.making up fake profiles so you can see what the pft boys are saying.bit childish really
It's a private group so I don't feel the need to explain myself
