Cockney
Link RemovedMorning Norm! How’s the head?
just up couple of brews be ok /bit frosty here hate winter in this tradeMorning Norm! How’s the head?
Yeah I had to chuck a pan of warm water over the van!just up couple of brews be ok /bit frosty here hate winter in this trade
I put a bit of waterproofer in both coats
Because Kirk makes loads of YouTube videos doesn't mean he's right.
I put waterproofer in my scratch coat and I defy you to separate my top coat from the scratch.
What waterproofer do you use? Some on here are saying not to put it in the top coat if using lime in the mix?This is the way to do it...always used a water vapour permeable waterproofer 4-1 both coats been back to alot of jobs I did 10 years ago...still perfect today. Use around half the dose in top coat.
Hydroscopic I think they call it.From the tub 'Does not inhibit vapour transfer.'
close, but no cigar.Hydroscopic I think they call it.
Or a Printed shirt, lol.close, but no cigar.
Technically Kirk is right. But u won't have a problem if u have waterproof in the scratch coat. I personally don't like waterproofer as it can make the finish not as strong.Wondered about the comments from Kirk. See the copied youtube comments below.
Would they use different sand/cement in Down Under.
FIXIT
we put waterproofer in the first coat but not the 2nd coat
Kirk Giordano plastering Inc
Good evening fix it, I'd stop doing that, if you waterproof the first coat you have sealed it, In order for the second coat to adhere it need to adhere by suction or what we call a mechanical bond, you need a porous first coat that you make moist with water to accept the second coat which is wet. If you waterproof the first coat, the second coat will not adhere forever unless you apply a bonding agent over the first coat as it's now sealed. Bringing peace, love, and harmony to plastering The complete plastering encyclopedia on video, by the plastering messengers of Youtube
How does it not make it waterproof if it stops the rain from penetrating the plasterU are wrong @essexandy do your research. Waterproof is a sealer. There is water in your mix. Better to only have it in your top coat. Even gypsum say not to skim on to render that has waterproof in it. And most ocr readers don't use waterproof In them. Just because u do it with waterproof don't make it right. Iv used it myself in scratch coat and had no problems. But it's not as good as plasticiser. And u should not use waterproof if u put lime in your mix.
Plus waterproof doesn't even make the render waterproof so it's pointless anyway.
I thought waterproofer was some silicate something or other that swells and block ingress of water so it only slows itBecause it doesn't it only shows it down. If it rains long enough it will penetrate it.
Do you use lime in you’re top coat?Use free flow both coats all the way through it’s the dogs
Depends on the sand and conditions tbh budDo you use lime in you’re top coat?
What mix do you normally use on a s&c render job then mate??Depends on the sand and conditions tbh bud
Il probably get loads of blah blah that’s wrong ! 4-1 scratch coat 4-1 topcoat free flow in both silver sand rules of beauty never had a comeback or fail since using this method and rubs up to perfection!What mix do you normally use on a s&c render job then mate??
PoliteSame ratio for both mixes???
Ducking awesome mate doing internals on one tomorrow that I done a month or so ago looks sexual will put some pics up hopefully with sun on it.Same ratio for both mixes???
That’s a strong mix but everyone’s different, You’re methods you’re method mate!Il probably get loads of blah blah that’s wrong ! 4-1 scratch coat 4-1 topcoat free flow in both silver sand rules of beauty never had a comeback or fail since using this method and rubs up to perfection!
Don’t get me wrong through a lot of trial and error I’ve found my own way with s/c and do a awful lot of it! It’s totally against the way my old man taught me but works for me lolEveryone’s different, You’re methods you’re method mate!
What free flowUse free flow both coats all the way through it’s the dogs
Cemtone additive it’s the best I’ve found to work withWhat free flow
bostick is good the pick of them. Very good for making site mix pump toCemtone additive it’s the best I’ve found to work with
