Gyproc coving
Donzo
Been a while since I put some up.
But noticed on box packaging, use cove adhesive only.
I used to remember easy fill was in its spec to put it up. Looks like no longer for what ever reason. Why the change.
Use to sometimes use Lafarge fast set for gyproc coving, but switched back to cove adhesive. Cove adhesive is much better to use, it goes further and it's a better fine filer.
Easifill, was the only fail I ever had, even with the background keyed and a really pissy coat of pva.
Easyfill has failed a few times,,,,especially on painted surfaces for me.
I dry fit it first get my joints right, once it's all pinned up mark top and bottom, then physically key the background and a weak coat pva if it's painted.
If I've skimmed the ceiling and walls, I just wet it with my water brush until the suction is killed enough.
Cove adhesive is what I use it's good gear
Lionel Ritchie is good
The truth is out there.
Gyproc coving
