plasterjfe
cant find any rates for hacking off. what you fellers think would be average M2 for hack off
Is that an actual tried and tested rate? it would be 700 quid or does that include your skipnick0412 said:£10 p/m including skipping it
plasterjfe said:Is that an actual tried and tested rate? it would be 700 quid or does that include your skipnick0412 said:£10 p/m including skipping it
nick0412 said:i find an easy way with render is get a angle grinder/disc cutter, and cut into squares, then kango. comes of easy as
nick0412 said:no? done it a few times. score it into grids. then ur only taking off 6inches square at a time. only worth it if its hard to get off
hence the 'get some off the bottom then take it from the top down in small chunks'...richardbrown said:nick0412 said:no? done it a few times. score it into grids. then ur only taking off 6inches square at a time. only worth it if its hard to get off
thats what i do as well. comes off in nice contolled bits
yeh course but how much easier compared to having little bits off the bottom?...richardbrown said:i just find it comes off easier ...... when its cut the vibrations off the kango seem to rattle it off quicker because that section has no strength from the surrounding render.
does that make sence ?
kebab king said:Sounds like a good job for Connor to start on.
