Ok you know bestleaks don’t happen if you know what your doing ..air lock from removing and replacing a rad, unlikely.
no special tools required for pressurising or topping up, basic filling loop or gate valve normally.
technically yes they could apportion blame for heating issues....... or marks on the carpet , or damage to woodwork or oil on the drive or the pregnant daughter or water went in the electrics and now it trips all the time. or a fiver went missing .all equally bizzare and unlikely .
A lot of my customers tell me they are planning on putting radiator covers on and wallpapering everything after I’ve re-plastered. Problem solved.
Stevieo has had a date?You’re about as funny as Stevieo on a first date
Have you tried the Plumbers forum?leaks don’t happen if you know what your doing ..air lock from removing and replacing a rad, unlikely.
Thats as joyless as it gets, if your lucky the yucca turns up.You’re about as funny as Stevieo on a first date
How many plasterers can plaster? At least 1 less than you thinkHow many plumbers can plaster??? Or say, plaster a wall then fit a radiator? Lol. Ffs
Leaks dont happen if you know what your doing.leaks don’t happen if you know what your doing ..air lock from removing and replacing a rad, unlikely.
yepHave you tried the Plumbers forum?
Most stupid quote this year.wtf
Fittings fail over time and just cos there's no weapage when you leave dosent mean it won't develop....you think leaks just happen . the leak fairy turns up when you’ve left and T***s it all up.
really? get a grip.
Exactly even experienced plumbers have leaks.all sorts of s**t can and does happen.Even experienced plumbers have leaks. Keeps us in a job
Billy of all trades, master of none!!its a mugs game. i only still do it so i don’t have to have monkeys like you lot in who want to come and make excuses for why you made a mess behind my rads or around my light switches and sockets.
anyone who spends so much time worrying about callbacks and negative customers must be ruff as a badgers arse.
Think he is a rocketBilly of all trades, master of none!!
dumps gear on kerb ,parks van two streets away cos it won’t start without a bump.Filthy joggers and trainers. Ohhh hello Mrs jones.
Plaster around switches? This is about rads you spazyou:
hi mrs jones it’s only me A1 spaz plastering. don’t get up mrs jones put your feet up while i crack on and me and wez will smash this out in no time mrs jones. only thing see, i couldnt get that plumber or electrician and when i was in college they said its nicer if you plaster round them anyway see mrs jones.
just sign this to say that you’ll be happy for me to crack on and smash it.
oh ye mrs jones , it will cost a bit more cos i got to bring me plaster right out now to the front of the light switch mrs jones to make it look nice mrs jones.
yes please mrs jones 2 sugars and 3 for wez.
me:
morning mrs jones, i’ll just whip these rads and switches and sockets off quickly , it’s going to take me about 2 1/2 days altogether.
then i’ll nip in saturday morning to refit the radiators . yes please mrs jones 1/2 a sugar .i’ll just stick this plastic protector to the floor so you don’t go a7seways and break your hip if you need a p!ss.
I'm just struggling to understand why anybody would be bothered tbh,either pay £40 to remove or don't,if you don't they clearly not arsed themselves,if its a painted wall its really not that had to blend it to a point behind a rad where you can't tell.who cares..not sure why socket faces got brought into it as thats nothing to do with radsI think we can finish this thread with
If you don't want or know how to remove then leave em
If you can and know what your doing then do so
As you where lol
So you’ve met Cockney then?dumps gear on kerb ,parks van two streets away cos it won’t start without a bump.
Now all you have to do is convince them you've left the perfect surface for wood chip.A lot of my customers tell me they are planning on putting radiator covers on. Problem solved.
I do tell customers that it would better to remove them some do some don't. Those that don't get told that you'll get round it as best you can. The idea you can't get an acceptable finish behind a radiator is nonsense,what are midget trowels, margin trowels and pipe trowels for.I'm just struggling to understand why anybody would be bothered tbh,either pay £40 to remove or don't,if you don't they clearly not arsed themselves,if its a painted wall its really not that had to blend it to a point behind a rad where you can't tell.who cares..not sure why socket faces got brought into it as thats nothing to do with rads
bodgersI do tell customers that it would better to remove them some do some don't. Those that don't get told that you'll get round it as best you can. The idea you can't get an acceptable finish behind a radiator is nonsense,what are midget trowels, margin trowels and pipe trowels for.
who cares? see , therin lies the problem .I'm just struggling to understand why anybody would be bothered tbh,either pay £40 to remove or don't,if you don't they clearly not arsed themselves,if its a painted wall its really not that had to blend it to a point behind a rad where you can't tell.who cares..not sure why socket faces got brought into it as thats nothing to do with rads
actually it’s about halls and stairs cos it says at the top. that makes you doubleultraspaztasticPlaster around switches? This is about rads you spaz
