essexandy
The Lake Governor
Fuckme another tight northerner. Are you closely related to Mr Squeaky as well?Building paper on the lintels and EML on top of it. Old plaster bags with the plastic left in does the same job as building paper
Use plenty of pva then if using bonding. The jobs I've quoted for lately and the so called plastering I've seen you are better off doing the work yourself. Trades gone down the pan.Haven't got the room. I've got about 9mm along the stair stringer.
The wall is out of plumb by about 15mm at the top of the stair wall.
I've floated walls with Bonding before so I'll give it a go.
A'greed ! He really must be a proper "time served" right tight c**t mate ! They are on the increase you know !Fuckme another tight northerner. Are you closely related to Mr Squeaky as well?
That would be tellinFuckme another tight northerner. Are you closely related to Mr Squeaky as well?
Go on , live a little !That would be tellin
Not sure whether we can claim off the Council. If they had not left the pavement in such a state then she wouldn't have fell.
Going back to my floating query. I have found a sheet of cement board in the shed. Can I screw this to the wooden lintels and float over with Hardwall
ChancerThis thread is a prime example of people over thinking things.
Wooden lintels above internal doors used to be completely normal, same as the roof plate at the top of walls they just require a strip of EML nailing on them. The EML strip should be wide enough to span over onto the blockwork.
Yes technically it should have building paper underneath the EML, but I can guarantee you that in my forty four years of plastering I have never once seen it done.
