Heat from inset gas fire is cracking the plaster above the fire. My plasterer used Multi-finish plaster over 15mm Fireline board. What can I do to fix it? Anyone any advice. AMA
John, thanks for the quick reply. I have heard of Vitcas, but how do I get the cracked plaster off without distroying the plasterboard? The cracks are only small and the plaster is not loose it just looks bad!! AMA
