Heat plaster
Phoebe
Hi there can someone remind me please What to use to plaster the inside of a fireplace. Customer is having a log burner installed to obviously gonna be some heat there so wanna avoid cracking. Thanyou
dry line it with the fireline plasterboard, the pink coloured one, and tile on the board with large black tiles. then it will give you a finished job.
sand cement and lime then top with victas plaster dnt use any beads thier prone to expansion and contraction
yes i heard that fatarm it wasnt called JJ's i think its called FF fat feckers now:RpS_drool:
Yeah that's his new branch FF but the old one is defo JJ's :RpS_thumbup:
I've been there once or twice :rolleyes)
Heat plaster
Heat plaster
Heat plaster
Sorry Phoebe this might not help you, unless you are hungry :RpS_unsure:
no you cnt dab wnt take the heat and the board will delaminate and the fireline boards although will take more heat than white boards will only take it once its all thier designed for, before the gyproc core will start to break up just do it properly sand cement lime with victas plaster to finish
it must break down in a very slow process, as the ones that i have done 25 years ago show no signs of deterioration.
