Help !!!
By covering the head of the Rotor, he refers to priming the mixing chamber which is the only way you can start these correctly so would have been covered with different terminology. If this isn’t done, you will jam the machine.... probably explains what’s happening....
Ok have seen a lot of different terminology on here like just starting to get grips with it all
So can you just squirt it in water chamber and pump it through worm and pipes during priming stage ?
Wet your hoses through, use tap on machine or tap with pressure, empty them out and a good squirt of squeezy in the end of mortar hose you connect to machine, get mortar as wet as you want want it before attaching spraygun to hose.
Cheers Mate with my knowledge being very limited these tips are invaluable . Thanks
