Mix some SBR through your pva will helpGuys looking for a bit of advice.
What is your best remedy for high suction walls ( Lath & plaster ) before you apply multi finish. Never really used a suction control primer before & would that be adequate anyhow?
Or maybe use UNIBOND pvaMix some SBR through your pva will help View attachment 49377
Blue grit doesn’t kill suction . Just provides a key for smooth surfaces . Try some sbr in your pva . Works a treat .Thanks mate. I detest high suction walls. Do you use any other suction control primer other than PVA. eg Blue grit?
Great tip . I’ve recently stated buying unibond or evostick. Can’t believe the difference well worth the extra cost . Tried explaining it to my mate but he can’t get his head around it . Cheap pva is false economyOr maybe use UNIBOND pva![]()
You defo get more time on blue grit in some cases,sometimes takes years to go off.i dont like using it tbhBlue grit doesn’t kill suction . Just provides a key for smooth surfaces . Try some sbr in your pva . Works a treat .
Ano what you meantam,what is your view on the forthcoming armageddon,4 horses of the apocalypse which is heading our way,.....you see, let you into a secret can i get my fellow spreads to listen to me , do they hang on my every word and advice, no,.....will they listen to me, no,......mmmmmm i think that was it, okey dokey pig in a pokey
I am actually changing my PVA to evostick and expecting 10lts tomorrow.Great tip . I’ve recently stated buying unibond or evostick. Can’t believe the difference well worth the extra cost . Tried explaining it to my mate but he can’t get his head around it . Cheap pva is false economy
Just ordered Evostick PVAOr maybe use UNIBOND pva![]()
I will get some SBR for future thanksMix some SBR through your pva will help View attachment 49377
Not a bad 2nd choiceJust ordered Evostick PVA
There’s sbr and then there’s SBR!!!I will get some SBR for future thanks
Tool station do it at a good price I thinkJust ordered Evostick PVA
Try your local PTS city plumbing . They selling 5ltr unibond for £9 . I got last 2 today .Tool station do it at a good price I think
Ordered a couple cheers fella , great shoutYour welcome.
They must of f**k*d up . The 10 litre is £51+ vat .Ordered a couple cheers fella , great shout
Yea I see that tooThey must of f**k*d up . The 10 litre is £51+ vat .
