Home made trowel
I had one of them big plazzi's with the foam and they do warp and bend. Good fix mate I like it.
Cheers, its fine for running up and down and quickly flatten in. Was waiting for one of these Nela plastic ones but there like fecking rockin hoarse s**t......@plasterers1stopshop ...........
Tell you what I think that looks wicked
Wish I had trowel handle like that sometimes on my Speedskim.
That's why I tried it like that mate, the larger plaziflex was to flexable the trowel only touched 1 3rd of the trowel face a waste of time, plus fed up with having to wet and dry it. Same here have the speed skim to flatten with thought having a handle would be good, as the speed skim has a proven blade. So come on SPEEDSKIM.......make a trowel version lol.
Seriously like that badgerrr and agree I do like speed skim handle they have but when I do walls with 600 sometimes I tend to grip the pole attachment which I leave on..think its probably habit from using a trowel for so long.but like ya say I wonder if @Speedskim has thought about some kind of handle attachment.
Got a small paint roller handle which works quite well,
Home made trowel
Home made trowel
Rossi they have had a over night soaking with some bicarbonate but still could do with another soaking ..I defo send them Saturday.
Couldn't fined the 20 inch but there is a supaflex 16 inch,2 marshalltown and a bg trowel I used for dabbing..
Good luck with um,
You should call them the Rossiflex
Good luck with um,
Mate you're an absolute legend! :numberone:
Another new trowel your going to give @thepla
get a second pole attachment and then cut poles down to handle size and have one at each end.
Glad you found one vince, I find it handy to use.
I've got that handle also quite useful on low lids also
I use a deluxe extension pole (a bit pricey but absolutely solid) on ceilings but on walls I kind of flip from gripping the speed skim handle to gripping the attachment which I leave on my 600,this grip you found has just made the wall flat and finish so much better been looking for one this small for a while,made my day,I will still use me extension pole on the lids that's fine.
Thanks again
Vince.
all you need now is a cleaning brush :D
Hay the sponges and rolled up cleaning clothes in my box are brilliant for cleaning windows ,Upvc,and basically any thing on domestic jobs that gets a bit plastery dirty and those big sponges clean speed skim blades quick time.
