how much per metre for putting coving up
Render Systems said:
I charge £2.00 per ft or 300mm and can whack loads of lm2 up per day if site work... its a doddle once set up... i chalk line the walls then put a few nails in chalk line to support cove... then use a bench to run the sticky on... easy do 100 lm a day
I've both done and had loads of coving done for me and neither I nor any other cover working for me has ever needed to use supporting nails on Gyproc cove on new work, if you need to then your doing something wrong ???
TonyM said:
richardbrown said:
I met a guy the other day who charges £2 lin m .... he did a 4 bed house on his own by lunchtime !!!!
Was that Chris from Wadebridge?
No mate he was from ashburton way ......... and was really impressive, measured up with 2 sticks and stuck up his coving with a mix of artex and dot and dab adhesive 50/50.
perfect work and a joy to watch
warm water mix artex or bg cove adhesive ..no need for nails on gyproc i ve been throwing it up for years .only on plaster cornice have i needed nails to support
only time i ever use nails is if the ceilings got a hollow in, just to help support until the adhesives set
