No this is bad
how do you stick yer beads on StanbroI always 2 coat, flatten in, then couple more trowels. Just seeing if there is alternative that's easier/better
Depends, staple them on, nail them or stick them on with skimming or pink griphow do you stick yer beads on Stanbro
why so many different ways?Depends, staple them on, nail them or stick them on with skimming or pink grip
Depending on background. Usually staple on board work, and if reskim try clout nails or sticking them. What ever seems best at the time. How'd you do yours ?why so many different ways?
check out thread "new system for beading" see what you think.
o come on john Yorkshire puddings /but I think Scottish style lolWhat is that lol
To be honest if you are any good and your eyes still work, you shouldn’t be able to fault your work with a trowel none of these things people come up with should make a difference to the quality just making it easier. Obviously I don’t fall into that category as I am rough, slow and expensiveThat's not the case with me. I was just wanting to try something different and see how it turned out. Like I said earlier I've seen results of a sponge finish from some lads and can't fault it.
