Always mate spend a good while masking up,saves loads of time cleaning up afterwards.pwi said:Do any of you lads tape up windows doors facias etc when spraying
McPlaster said:Ofcourse duck tape and coverup 550mm from Leslys, cheap as chips and worth it.
goody said:difference between a mint, sharp job and an ok one.......put your angles around the windows and plumb up stop beads that butt up to the window in line with your angle beads....then use a waffle plane to scratch them back. neater, more visually satisfying and gives you a nice edge to mask to when covering the windows.
naz said:hows ur machine rich?
naz said:shouldnt be 2 bad we been spraying render all week apart from 2day, it will be fine. where u off 2?
Paul we got caught in that bout 4.30 , f'cking funny agent started panicing told us to stop spraying,lol little bit too late. ;Dsimplybesty said:we sprayed in a snow storm today, never seen anything like it. couldnt see stu on the scaffold so it must have been bad ;D ;D ;D
richardbrown said:dont listen to the above two posts ...... just bang it on, cover the windows the lot then spend 2 days cleaning them.
thats what we do
