S a plastering
Hi does anyone i bar there weber ocr then sponge up instead of ruling it when its all on when wet wss going to try it this way if it works thanks
Just get a speedskim over it and jobs a goodun.Hi does anyone i bar there weber ocr then sponge up instead of ruling it when its all on when wet wss going to try it this way if it works thanks
Cheers andy i know about speedskim done it loads of times an normally use a serrated edge to stop any air pockets just wondered if with the i bar would be betterJust get a speedskim over it and jobs a goodun.
I barred ocr a few times not the Weber tho but yeh I bar and sponge comes out flat as a f**k and sponges really well used to do it a lot with Sto level cote before topping with amorcoatHi does anyone i bar there weber ocr then sponge up instead of ruling it when its all on when wet wss going to try it this way if it works thanks
Same can't see the point in not meshing peace of mind for £40 a role,i like to mesh all my renders. would you still do that in 1 day? or put a scratch coat?
ahhh thats good coz i was dissapointed in who i was looking at .lolSame can't see the point in not meshing peace of mind for £40 a role,
That's not me I'm sexy as hell
Yes on new work, on a hack off I'll rend aid or keycoat out and bed mesh and hit it with one coat when cured.ahhh thats good coz i was dissapointed in who i was looking at .lol
you do 2 passes with mesh same day then mate?
Do you bed mesh in with the rendaid and then go over with stipple roller . Just thinking it’s got to be a fail proof method on all backgrounds surelyYes on new work, on a hack off I'll rend aid or keycoat out and bed mesh and hit it with one coat when cured.
Yeah two passesI though you were supposed to do two passes . Especially if no scratch coat . I used ocr before in one pass and when it dried you could see every block
I always do two passes hence meshing outI though you were supposed to do two passes . Especially if no scratch coat . I used ocr before in one pass and when it dried you could see every block
Yes mateDo you bed mesh in with the rendaid and then go over with stipple roller . Just thinking it’s got to be a fail proof method on all backgrounds surely
Do you normally rule off the first pass before putting the second on or just put it all on in one hit?
Two passes doesn’t stop blocks showing it’s the thickness normallyI though you were supposed to do two passes . Especially if no scratch coat . I used ocr before in one pass and when it dried you could see every block
