Im plasterer from London
wheres ya internal for the corner ? and also wheres ya hi vis hat, googles , gloves , safety harness did you do a risk assesment and ladders are for access only you need a full scaffold set up to do them walls make sure it put up by proper folks and has all the right paper work etc
Half way through that you might have been better pushing your thumb up your bumhole.
At that point there could be no arguement that it was not done correctly.
However given the lack of evidence, this judge rules that you are proper shite at skimming let alone the finer points of spreading......ie. wearing panties when the householder is absent....or perhaps shitting into a bucket without splash from 2 feet.
40m ceiling....fu.ck off. maybe 25 and i would bet a G that a small strike of sunlight across it, would make even the tightest anus release and s**t itself.
