Hi there
I have a 1930s bungalow which has had really bad condensation / Damp issues in the main room
This room is also the coldest room of the property and doesn’t heat well with central heating (we always use an oil heater for inside the room)
I have been advised to unblock the vent( which is completely sealed and not visible from inside the room) but was concerned that this will make he room even colder and cause a draft although I know it will help ventilation
My thoughts are get the vent unblocked and then insulate the walls
The question is do I Insulate from the inside as this is the only room that is cold - if so how thick would the insulate be so I know how much space I lose
Or should I insulate the from the outside which I know is going to be more costly as I would have to cover more space
If anyone has any advice that I would appreciate it please
