internal angle trowel
broonster
Fellow Tradesmen,
Have had lot of problems trying to obtain a good angle trowel the last one i got is just to tight and youve realy got to put preasure to fit the corner i think it could be for drywall.Not to sure about marshalltown.Any suggestions.
The MT 90 degree angle trowel is spot on :-)
I would not recommend their adjustable plastic trowel unless you intend on using it for angles greater than 120 degrees. For angles between 90-120 degrees it is so badly warped it does not hold a true straight angle.
its a good tool where the work is nice and plumb and square, i have two types one for nice new work and one for refurbs..
a wet angle is always a nicer finish to a dry angle, ive got the marshalltown one but not sure what one angle it is ive had it about 7 years, but i think its pukka, although i have bent the wings in slightly so it could have been the bigger angle one and ive reduced it
I use one of those little cheapie things off fleabay, there's a thread somewhere..
Though I carved a bit of wood into a handle and shoved it in the tube as you tend to scrub the walls with your knuckles otherwise.
Premium Quality Stainless Steel Corner & Angle Trowels For Plasterers
I use the one at the bottom of the page......................they are mustard.....................:RpS_thumbup:
I had a tyzak one of these which i got with my first set of tools in 1980 and which £1.50 per week was deducted from my wages until all my tools were paid for then 2 years ago some thieving she-ite had it away i was gutted. As the old spread who told me which tools to get way back then "you can never guarentee that the trades you follow will make a 90 deg corner so get a twitcher"
It was jeanclaudevangyproc that was promoting them if I remember correctly?:RpS_unsure: .....wonder how much commision he got:RpS_wink:
Tyzack internal and external angle trowels still come up on ebay, this one is for sale now and an external angle trowel is also up for grabs
  • internal angle trowel
Not all corners are 90 degree though. So you must stand there scratching your bollox when you realise your corner trowel doesn't fit
That's why I have a selection of angle trowels, if its an extreme angle you can do alternates like the old days, some still do it this way.
