You say the wall will be insulated- how? By putting celotex? And how will that insulate the wall with , as you are stating, with air gap , which will contribute to more condensation behind the wall. It's not a cavity wall. By doing all this you will replacate IWI, which in my opinion turns every room, house in aqarium.Why? Because doesn not leave much of hot air through and does not help controlling the moisture in the room.This system is more likely to be seen on site, but now is slowly changing to better execution- ready panels. Normal cavity wall does not work as it should do to moisture bridge and temperature loss. However , the new panels are much better! Brick in front, wp membrane , insulation and closed with concrete. That's close to the maximum requirements to make a cavity wall working- wp membrane is stoping any water to pass which makes the whole difference . In your case water will be always there and trapping it behind , or , within the wall will make no sense. Any solid wall should be able to breath and dry . The difference between site building and domestic is site walls are trying to minimise moisture penetration to minimum whether . Houses will have to deal with managing the moisture penetration and evaporation . That's the bottom line and you can't mix it. If the label says insulating, it doesn't mean that in your case will work.
Thanks for reading and good luck
