efc plastering
Any lads on here used Ival products they're Italian but based in Teale , Berks using Klebochem base coat it dragging like fook
you're right its a lot different from hp12 you can get a nice finish with the sponge,i've used other gear were you cant sponge it like Relius German glebe you just leave off the spatch but this seems a lot more high impact , its a Mite site in Irlam by the way,thanks for the advice Jfe
the spec for Klebochem is next day final skim coat - but you can catch it same day, lay your mesh then spatch it through only just the surface, then keep meshing let it go hard (but still green) enough to press your trowel hard on your second pass then skim it out like you were laying down skim with a slightly looser mix it will go on about a mm and finish off the trowel. do not sponge it - it is a premium base and has alot of chems and fines it wont like the sponge say as wetherby does with all the aggs and bulkers in it thats more like a masonry mortar.
What site you on ?
