Job spec
putzy
Hi all got parex Specked job comeing up . Tradirex inside onto block floated up and then tiled over. Outside parmurex float finish then painted . This Is a high spec job clark of works permanently on site as is architect. Opinions on products would be appreciated .cheers lads oh one other thing there will eventually be uplighters outside.
You'll need good plasterers for that mike people who can use a straight edge! As for the material not used it, but the inside work done loads using schell putz beads plumped in and lined up, and walls squared up stuy
if the uplighters are close to the wall i would rule in the vertical position . if they are a couple of ft. away i would rule in horizontal.
i thought that parmurex render was one of the trowel finished renders
