K lime
get a small disc and cut in half it works a treat if you need to snap your lines use white chalk
Tried this one long time ago, does work a treat, only problem is another day,another visit to site, nether the less a good tip .
:RpS_thumbup:
We tend to use a couple of old 6 inch nails which have been rounded off so do not scare to deep. Catch the gear not to wet still as this can make lining out difficult.Once scored a gently brush over with a nice soft brush to loose the spoils of the scarring process.
update on how we got on with the k lime
we mixed some in the mixer for small areas and dubbing out ,nice gear goes on well ...
in the plastering machine it was a bit of an arse to get right (we had a new clamped rotor & stator to wear in too)
tried different water settings and as has been said before it has to be wetter than you would like
apart from a material hose blockage ,once the water was sorted (425 ) we put 75 bags through with little problem
as mark said above
if you had a diesel machine you could prob spray it bit drier and being more powerful would help?
:RpS_thumbup:
as mark said above
:RpS_thumbup:
Thanks for the up date Martin,
I guess you used the 213 grade. Im pleased to hear it went well after a bit of tweaking.
Just got back from sunnung myself in Turkey, so back in the tread mill today :RpS_crying:
k lime
we only bought our s/h mschine last year so having now tried a few different materials we come to the conlusion klime is not best for electric machine
since last years post on this
material we have used it a few times
small areas were done by hand ..find the material goes on fine with a
quick set ,nice even colour when dry.
just doing 160 metres external on a house nr usk have had to again spray
wetter than i would like...reducing water tends to block hose,esp when stopping to move to new lift..
we continue to try different similar products
think.we will look for a diesel machine for this type of work ..
I have a genuine Tyzack Ashlar jointing tool. I will be retiring soon so first established rendering section forum member who wants it can have it after I retire. PM me your email addy and I will post it on when I officially have no more need for it.
There will be a load of equipment coming up for grabs but i will post them on here come the day.
The tool has now been promised to a regular poster.
