nickelarse
would weber lac do the same job over paint?
mark where in south london are you based? would you ever need a tag along so i can see how you setup for a job like this?
As Owls says, it is not a good idea to start loading additional renders/weight over exixitng ones, We have a job starting soon, there is some patching required,MT112 to a carrier board and a fair amount of patching using rendaid and OCR.TF 150 to existing painted render.
Weber recomendations to existing render was a wash with CL150, PR310 , and a TF 150 finish.
I did express some concerns regarding coating over existig painted surface ( done approx 2 years ago) , however they seemed fairly posoitive about this.
We will jet wash it to start ,this will give us an insight into its integrity.
No plroblem, we have a few on the books this year. I will advise you accordingly.
Correct me if I'm wrong but parinter isn't suitable for a dpr finish? Something to do with lime? Two coats of maite with mesh then dpr? Has anyone tried the parex clear sealer on mono to stop staining? Seems like a simple fix if it works
parinters fine with dpr, weve just done a project and got the warranty after a visit and a spec drawn up by the parex lot.
also for some reason the parinter is 30% cheaper than maite
no one wants to answer me :RpS_crying:
can lac go over paint?
Hi, the guns a M25 600mm angled head, a 14mm cap and a Unistar 1 ( M300) . air nozzle at 15/16mm back for nozzle from cap outlet.
Nick, Weber do not endorse the placement of the LAC over exisiting painted surfaces. They will tell you to remove the paint,wash with cl150, prime then lay on the reinforced LAC render.
Not used the Parinter personally, but maybe go the Parex route on this one.
Have always thought maite is ott for a lot of things compared to other adhesives etc. do you reckon it could be used on more things than paint ie. eps etc? Does it have the same body as a regular adhesive?
