K - rend
Hi mate, you will be fine with your D,6-3 P1 - a spray jet is an extra you could go for. This will disperse the water and allow for a slightly better mix
Use a d 4-2 clampable. K rend silicone will go through the G4 very well. Set it at about 12 bar and try maintain the 12 bar everytime you pump test. You will get 25+ ton and should see a saving on generator fuel because the machine will not be labouring as much.
we spray it with a 4-2 no probs and no jet.
just think at 0.8m2 per bag how many more bags you will need on a job that size compared to another, the money saved on that size would be magic in your ar5e pocket
a fitting with a reduced hole to form a jet rather than a stream of water that goes between your water feed pipe and the mixing chamber
