S a plastering
Do Krend do a base coat for going over cement board and brick combined thanks was thinkin more weber lac myself
can you float hpx to a nice finish its going to be a bucket coat finish thanksi think its hp14 or hpx?
Hpx over the board then use hp12 to float.can you float hpx to a nice finish its going to be a bucket coat finish thanks
cheers go over the board with hpx then use hp12 on brickwork then go over the lot again basically 2 coats then float up?Hpx over the board then use hp12 to float.
ok cheers I've only ever used it as a scratch coat for mono what's the process for floating it up to a finish for priming and 1.5 top coat thanksJust use Hp12 over the lot. Its specced over cement board and brick. Might need a splash of R7 on the bricks.
No need for HPX, unless you like pi**ing money up the wall.
FT is worse, i’m Handballing 50 bags tomorrow.Hp 12 is nice gear to use, as with any k rend base it's all good,Shame there k1 is gash.
6mm if you can do it mate. Nice stuff to use as said. Not sloppy like some of the polymer bases.can you get hp12 up to 10mm beads on same day or is it better with 6 mm beads
cheers pal is it ok to float up an what stage want it ready to prime an finish cheers6mm if you can do it mate. Nice stuff to use as said. Not sloppy like some of the polymer bases.
Ridulous.FT is worse, i’m Handballing 50 bags tomorrow.
It's a pain to spray, it sags on the wall, and also it shrinks when it's drying and you get resulting cracks.Gash in what way? I'd agree FT can be a bit heavy and teary but K1.. It's fine.
We do a lot of the Silicone I actually quite like it, it's one of my top 4.
Only took 42, don’t miss them days no wonder my body is f**k*d.Ridulous.
I liken it to buying a car you’d much prefer the Germans or French to make it for you over the Irish.It's a pain to spray, it sags on the wall, and also it shrinks when it's drying and you get resulting cracks.
It's the composition of it.
If if it was the odd renderer that says it you'd think yes ok it's applicator issues ,but everyone murders it.
Look on Facebook on the machine forum, or previous posts on here, none of my sub contractors will use it anymore either. A cheap shitty render.
Thanks for the rendering lesson...I don't murder it.
If you're getting splits it's trapped air, slow down marra, soften your mix and get the air out and pull the gear together on the spray lines. Weber traps air as well given the right conditions which can make it look like its been shot gunned instead of splits.
It's from running too stiff with a quick flick over with a straight edge. Work the gear.
Don't have any sagging problems here either got a 800m2 job starting next week in K1 grey, no bother.
Does no one learn their trade anymore? We literally will spread owt.
Here's a question if one man makes a pukka job of Krend and 3 others f**k it up who's the numpty?
Is it light for hand application?I'm using kilsaran mono at the mo totally diff very small grain and a very slow setter nice too put on though
I've used loads of hpx mate shhit for getting flat that kilsaran great gear mate and the base coat were in cheadle doing the top of the houseIs it light for hand application?
Madmonk I'm pretty sure Krend have another base coat now called hP14, whatever you do don't try use hpx as a flat finish it's a nightmare.
My current render choices are
Johnstone's TC
K1 (as you know most want k rend around Cheshire) although we got a few nasty ghosts on a job the other day with K1.
OCR Kmix but I'm Keen to give Weber a go
Anyone any tips for ghosting on K1?
It's not a case of learning the trade incidentally I've been using scratch renders for nearly 20 years now and we apply ten of thousands of metres a year of the stuff across various manufacturers so I've got an idea of it.
I'd maintain It slumps down the wall and has no body to it compared to other quality render i.e. Monorex, pral m enewall etc, they simply don't do this, and I'll stand by my statement that I know dozens of experienced Renderer's that won't touch the stuff.
It's only ever you that pips up and defends k rend, am I wrong in assuming you have some sort of a interest with them,that you will admit...
All you do is occasionally crop up on here when lads slate k rend upon using. I still maintain it's a poor quality render, if I was in the minority in that I thought that way, fair enough I'd accept that but look through the long list of previous posts on it, on here on the machine Renderer's forum on Facebook etc, all of us experienced Renderer's can't be wrong especially when no other manufacturer draws such flack.Sigh, I use it a lot, customers ask for it a lot, it's probably the most asked for gear there is. I make money of it. I'm going to criticise guys who make out its crap because they can't handle it. A nicely done job in this gear looks as good as anything else out there.
This is their and my livelihood, just learn your gear and give the punters what they want with a fecking smile.
Jesus, I had a decorator tell me that Dulux was crap the other day. Are tradesman really that dim?
Why am I constantly crying you moron all I've said is its poor quality to other renders,it's a forum people give there views, based on practical experience and it's no coincidence that no other manufacturers draw such complaints. I couldn't really care less, I'll just use and do use other different manufacturers. The spraying of all renders will gather air when spraying that is what your h bar is for, as if used correctly it will take these air locks out.I disagree with you and you don't like it when you're used to being in an echo chamber. Its ok to have preference to material, I prefer my own stuff. Some guys like a dense meaty feel under the trowel, some like it to have no feel and full of air. That's fine. You need to get your head around that fact that there will never be a material that suits every spread. Ever.
Constantly crying because something isn't how you like it is just..... Tedious sir. One thing K rend does a bit that a lot incorrectly moan about is trap air in between the spray lines which can create small horizontal splits that need filling during the scrape. These get described as a "crack," quite a bit, its not a crack its a quick lazy whip over with a straight edge when spraying is what it is. Get the air out and these don't happen. Back in the day they used to teach you about getting the air out of your spread, these days its all about getting the phone instead for the hollywood selfie on the latest job.
